96BlackSE
I get them made at a local machine shop, let me know if you would like a set...
They are only available through this GB
Who are these made by? I may be interested in tossing out some money on these.
if i have the udp and if i install this two pullys you send will be a gain or i need to uninstall the udp? or can be the 3 togheter?
I believe somebody was using all 3 together, I am not sure what the results were but the entire point of these pullies were to be able to underdrive the accessories with out an underdrive crank pulley
I am planning on trying all 3. We will see how it goes and how well they go together.
Try cutting your wheels hard over at low speed. I expect you'll get some resistance. Check your charging amps at idle too. I wonder how much juice you'll be pumping outa your alt with the crank pully added.
The only reason I don't like a crank pully is because the A/C compressor turns slower and the A/C system gets less efficient. An important consideration in Florida. The Alt & PS pully combo eliminates that problem.
I bet Mikey forgot all about this now that he has his STIonder:
