Been a minute after dealing with fuel pump issues...Started tuning yesterday running into woes. Here is some pics because everyone likes those.
80MM Lightning MAF > 90MM Lightning MAF IMO anything past 9PSI you should go blow through maf, so take my advise and dont be dumb like me. If i could go back in time i would.:fighting3:
42LB Lightning Injectors to 1000CC (95Lb) Injectors DW Bosch. Super overkill but bought for tuning data.
AEM wideband is being a grade a piece of :censor: and being jumpy as **** with voltage output
and lastly the bypass valve is causing issues with the MAF... so much air is being blasted into the intake side of the supercharger, its messing up the MAF reading, going to attempt to recirculate it closer to the supercharger. (see pic in red)
Taurus rail with modified return using same connector as intake. Keeps fuel in true return.
Had to convert the E1 hardness into EV6/EV11. As EV1 is very difficult to find big injectors for... Took a lot of work to get these in because the connector sits so much lower.
42 vs 95
Ugly mess
Cleaned up
Had to clock the injectors in the lower intake(s) so that the connectors would clear.
Here is 80 VS 90. 4" > 3.5" to Vortech Cobra head which is full 3.5"
Barely fits. Ha.
So here is how my bypass is setup today and where i plan to move the "return" Hopefully that fixes 1 of 2 major problems.
