Tourige
CEG's Resident Jackass
im not sure if this will work with contours as i am new to them, but from my past experiance with hondas there is alot to be had with gearing. going to a 4:9:1 final drive and also switching a few other main gears really helps accelaration, with hondas. do some research as to contour gear ratios, maybe you may find someone who builds transparts. just like putting 4:11's in a rwd car. combine a nice 3L build with a built trans and you might have something. huge horsepower numbers are nice but if you cant get it to the ground whats the point. just my .02
Gearing options with the contour: Normal Gearing. Or.... Normal Gearing with the Zetec Final Drive.
The gearing is fine in our cars.
