F111D F
When you get the leak stopped, I pulling for you, go to Advanced and get quart
Of "Right Stuff De-Ruster". I put mind in an empty trigger spray bottle and soaked the rust. Let sit over night the rust is converted and then that is turn in to "phosphate". It best and easiest way stop rust and this surface paint or coatings bond so much better.
This stuff a boon for us rust haters in salt country.
My next steps are priming with Rust-Oleam's "Cold galvanizing and the Zinc rich Cold galvanizing paint. If I had the money I'd use POR-15 but as parts are getting harder to come by for the Tours not sure if I need to last that long?
PARTS. I take it the Cougar filler and gas tank parts are the same?
TNX
Just found out that Home Depot has Phosphoric acid and I'm sure any automotive paint supply. Use eye protection!!!!
TNX
