starting on my list ...
1. I want to pull the turbo again for a few reasons. this weekend, beginning of next week.
3. try again to track down my my instrument cluster will cut out. seems to be the fuse interior fuse panel or a connection to it. looked last night and didn't note anything odd.
4. in general get some more miles driven on the car so I am comfortable driving it to SZ done and done ...
5. Install Samco Hoses will do when the turbo is out of the car
6. Need to install new rear brake pads. currently working but pads+rotors still don't fit in the caliper. will either have the rotors turned or sand down the new brake pads more
7. After a few more miles on the NPG brake kit I should pull the rotors and paint the unused rotor surface.
8. install DDM tuning HID kit kit is installed, need to make brackets for the ballasts
9. figure out what wheels are going back on the car and make sure the tires are good on those wheels. the supperleggeras are now on the car.
10. install steel braided brake lines
11. repaint calipers T-Red
12. install new sway bar end links.
- up-pipe needs to be rewrapped with header wrap. might use the silicone paint this time
- I want to put the 8 lb spring back into the wastegate. currently have a 3# spring
- as a safetly precaution I think I will change the oil drain rubber hose, or replace it with steel braided line( need to find out if that is a good idea being near a heat source).
- buy and install proper gaskets for the turbo and wastegate purchased metal gaskets for turbo and wastegate, need to install
- need to revisit battery relocation and add battery switch or in line fuse since I had issue with the circuit breaker I have.
