Well, I got the header on today, it took pretty much all day though :blackeye: .
It is definately louder but I think I can tell a slight difference when accelerating hard.
Funny story:
After getting it on and picking up the tools I decided to head to the gas station and fill up for a test drive. When I gunned it for the first time it gargled like my old 86 lynx I had in highschool with a shot muffler. I was so heartbroken - I mean I knew it was going to be loud but damn. The odd part was that it was loud under the hood - not from the back. I was going though everything in my head and after a few blocks it hit me... I forgot to put the first (heated) o2 sensor back in the header
. By this time I could see exhaust coming from under my hood and the car filled with fumes. After I got back home I checked and sure ehough the o2 sensor was lying in the garage. I installed it and headed out with my wife to our old house we're selling. The car was much quieter, but after awhile the fumes came back... strong... Later that night when we got home I popped the hood and looked around with the engine running ... smoke/exhaust was coming up from around the header... after another few moments I realized I hadn't put the oil dipstick tube back in. After installing this the fumes went away. :nonono:
Moral of the story: Pay attention to what you are doing and put everything back where it should be.
More info for those wishing to install this header:
I ran into a few hang-ups along the way:
1) Removing the factory Cat. The tube for the EGR valve was rusted to the cat and I had to end up cutting it of with a hacksaw - part of the problem was the location of the nut.
2) I couldn't get all four studs out of the cat where the exhaust manifold connects to the cat so I had to pull the Cat down first then remove the manifold.
3) In order to pull the cat down I had to: (item 1 above) and cut through the strap that holds the cat in place as this was rusted in place as well - prybar was a life saver to snap the strap.
4)The angle of the final pipe for the header is different than the stock pipe so it won't fit in the bracket at the rear of the engine. I just let it go without support at that location.
4) The Header requires two different sized gaskets for the connections on the pipe (middle and end) however it comes with two gaskets of the same size. The rear gasket was small so I had to cut the bolt holes out and center it.
5) No gasket was included with the header for connecting to the Head, Luckily I had one lying around (I have a complete gasket kit for when I have headwork done).
6) Because my car is a 96 with EGR, I now have a cut off tube in my engine compartment which will end up connecting to the air tube on my performance cat down farther on the pipe ( a certain cat is needed which has an air tube on the side). (This tube in my engine compartment originally went straight into the cat)
Other than what I've mentioned it went surprisingly well.
I installed this header on a 96 so I had some mods to do as mentioned abov. If anyone is wanting to do this I suggest:
1) Have plenty of sockets/extensions/whenches/pribars/hacksaw
2) Exhaust manifold gasket
3) Your own two-bolt flange gasket for after the second part of the header.
4) A full day devoted to working on this project (For those like me who aren't mechanics and to account for the rust factor)
Good luck.
Oh, last thing, after fixing my problems the volume came down. Sounds good now only a little raspy when first building rpm. This is with stock resonator and muffler. I will be going to 2.5" pipe (since I'm not going to pay for 2.25" mandel bent) with a performance cat (with air tube) and two magnaflow muffler in series (where stock resonator and muffler are).
Worth the mod in my opinion... will need a tune when everything else is done though.
Oh, also, after doing this mod I still DON't have the CEL. I didn't use a mil eliminator and have both o2 sensors hooked up. I'm not complaining.. just odd. So I've got the header and no check engine light... YIPPEE!
