00stealthySVT
well make a long story short, the 2.5 had a lite tap and my spec stage 1 failed. this is how it started
engine was taping for a while after i cornered hard.... knew it was gonna die so i bout a 03 3L. bought headers, spec 3 (before mine failed) 70mm mustang TB, lot of goodies, then i decided to turbo along with the 3L swap
pulled the motor, powder coated the sub frame, uim, valve covers, painted the motor mounts and brake booster... pretty much the engine will look amazing
heres the skinny
Trans-
Torsen LSD
New syncros and blocker rings on all gears
NEW updated 3rd gear
Updated shift forks
Engine-
03 taurus 3l with 72k
New clevite rod bearings
OEM main bearings
New OEM oil pump
ALL new timing equimpent
My SVT cams
Port matched heads
98 style return rail with standalone aeromotive fuel pressure reg with -6an fitting welded to the rail. -6an supply
aeromotive stealth intank pump. 340 lph (kills the walbro gss342 hp hands down for about 40$ more)
removed secondaries
egr delete
lower 02 delete
ac delete
04 cobra 39# injectors
ported SVT uim for 70mm mustang TB
twin 10'' slim fans
Turbo setup-
Garrett GT3582R
garret turbo blanket
Tial 38mm v-band wastegate thats watercooled
tial 50mm bov
3'' down pipe to 3'' exhaust
2.5'' piping to fmic 3'' from ic to tb
VMPtuning 75mm id blow thru HPX maf good for 650whp
x-cal 2
converted from returnless to return fuel system with key on hot via a relay
-6an braided stainless supply, 5/16 hard line return
ill post pics later tomrrow after work
heres the skinny
Trans-
Torsen LSD
Updated shift forks
Engine-
OEM main bearings
New OEM oil pump
My SVT cams
Port matched heads
removed secondaries
egr delete
lower 02 delete
ac delete
twin 10'' slim fans
Turbo setup-
Garrett GT3582R
tial 50mm bov
x-cal 2
