My 3l boost thread
im def trying! I have some stock cats somewhere, its just a pain to remove them, install the stock cats and reinstall the MSDS once they come back!
*edit* isn't it preferable to have equal lengths coming from each header into the turbo? i def dig the how clean it is, but just curious on differences between this and a equal length y pipe going to the turbo. I wonder how it will compare.
equal length in our platforms is damn near imposssible unless you do under the motor and trans, but even the msds's arent equal length headers sooo in a boosted aplication it wouldnt matter too much anyhow
that flex pipe in your hot pipe setup isn't necessary unless you have/had fitment issues or you plan on splitting the block in half someday :p
ooo well i might as well tease a bit since i have lots of pics and whatnot to get uploaded. but as of now, she starts, revs and idles like stock with a baseline tune...
newest up grades were the Aeromotive Stealth pump 340 LPH
welded a fitting to my fuel rail, for on the rail regs are just slightly to tall to fit under the plenum.
did a key on hot fuel pump with relay.
custom intank fuel pump assembly
sct xcal 3
braided -6an feed and return lines
aeromotive a-1000 fuel pressure reg.
ac delete
corbeau racing seats
custom harness bar
CF trunk
pre 98 dash swap
im sure there is more but ill have the pics up in a day or two
cf trunk
tig welding skill
crash bumper replacement
seats
modded fuel rail
fuel pressure regulator
modded top hat
fully custom fuel pump assembly
key on hot relay for the fuel pump and the pressure feed
gauges
ready to start
intake routing
