Hey guys so The cougar from hell is almost back together, freshly rebuilt engine, new clutchnet clutch and dorman slave cylinder, finished putting in new axles and brakes yesterday proceeded to bleed the clutch right after. To my pleasant surprise the fluid just kept going and going and going till we looked underneath and found a puddle. Seems the boot has torn or something considering I can't feel any fluid around the blts from what I can reach through the hole in the top of the trans.
Anyway my question is since we no longer have access to our engine hoist we have 1 of 2 options, either have ford do it for an arm and a leg when we take it to get rekeyed (new svt ecu) or change the slave without pulling the engine. Now I've searched for a while and found a couple posts, though they were mainly from 2005 so I wanted to get some fresh input on the matter. I've read that it is possible to change the clutch simply by lowering the passenger side subframe a little and dropping the bolts from the drivers side of the subframe then sliding the trans out with a jack etc. My question is can anyone give me a bit of a preview of what we'd be in for with this?
Also since it's just the slave cylinder not the entire (brand new) clutch that we'd be replacing, would it be possible to simply detach the transmission and roll it far enough away from the engine to get a socket on a swivel and extension in there without lowering the subframe at all?
Thanks in advanced for the help guys
