svtfixer
random thought. i know my e0 is cursed. built on an indian burial ground in kansas. who elses is cursed and had this slave blow on an e0?
number on the box was correct for us, not sure if the actual part was though. Will see soon since my buddy just decided to let a shop do it
I pulled the trans without removing the engine. It took about the exact same amount of work/time.
And yes, the subframe is still attached. Steering column must be unhooked, and pass side bolts must be nearly removed to get the SF to deflect far enough. HUGE pain in the neck.
Basically from what I've read from posts back in 2005, some dude named Stazi along with a few other people were able to do the project fairly easily by following the method of "No need to remove the subframe!! Leave the 2 bolts in the pass. side. They should be the first to be removed and then reinstall giving them about 4-5 turns. Then completely remove the driver side nuts and let it hang down. Don't have to mess with all the stuff attached to the SF." I jut wanted to know if anyone more recently has done it this way. We have the knowledge and experience just never had the inconvenience of having to do it in such a way.
