striker2
Official CEG Vendor
yeah, how else do they know that they actually improved the flow otherwise.
just curious if you've made any progress/new developments in the past month? i've been following your build since day 1 and i think this is the first time you haven't given an update for longer than like a week!
i'm well aware there is ALOT of waiting involved with all the work your having done and the turn around time for each process, as well as trying your best to stick to your monthly budget, but i was just curious as to whats goin on with #49?
-Mac
CSVT#49,
I was reading about the piston squirters that you had installed in the block. Since this is an additional bleed on oil pressure, is anything being done on the oil pump side to offset any pressure loss imparted by the squirters?
CSVT#49,
+1. I think the upper end will suffer most since the squirters will feed off the main journals and then the remaining pressure will head up top. Can't skimp on oil pressure, esp feeding a turbo bearing
Same setup as most Nobles... and they do not have problems. So I feel confident with the layout.
yes, but dont the nobles also run a drysump?
Superb thread, this is a really exciting project. I hope it turns out exactly as you expect. I'll be watching with bated breath.
Simon
What tyre size will you be using for this? I guess something big like 19x8J will help to get the power down.
you would be surprised how much more an 8" rim will grab over a 6.5-7" rim with the same tire size. i went from a 245 on my 7" to a 245 on my 8" and the grip was loads more, and then i put 275's on :drool:
Thanks. Things are going slow because there are a lot of custom parts and custom parts take time... the Manley one piece stainless steel valves are adding about another 2 weeks.
