I used the correct tool
CV Shaft Puller. You can rent the puller tool and slide hammer at any Autozone.
I just use a pry bar,works every time with out fail
How many times have you done this and on how many different cars? If they're popping out easily with a pry bar it's time to replace the retainer clip.....
Slide hammer and propper removal tool is the way to go personally.
part numbers 27033 and 27058
could also look into the VMP blow thru HPX maf... its 650 capable in a 3'' ID housing, its what im using
http://www.vmptuning.com/store/index.php?p=product&id=234&parent=99 entire unit
http://www.vmptuning.com/store/index.php?p=product&id=193&parent=30 sensor info
what rods/pistons did you end up going with? i dont feel like going thru 80 pages lol
no, you fail.
what heads are you using? the 3l? i dont recall anything about them
You have got to be joking.....look again. And try harder this time.
sure it is only 45 degrees today, just go steal tonys garage for a while. Push his svt out of the way![]()
