mean streets a good place, i had tham do a cage for me years ago. did you check into TNT also?
You have to be very confident in what you are doing to drill holes in the dash of someone elses newer car.
And since its close to your house, you gonna roll the car over there?
mike, so whats the gameplan with the car prior to the cage? (I'd imagine that is going to consume much of the available funding)
Actually I was surprised. The full cage, which is going to be all custom to fit my car was quoted to be around $1100-1600 depending on required tube size. Then the custom fuel cell to fit in the OEM tank size is going to be $300-400. I was expecting it would be a lot more. However at least I have some time to save up for it as he's not going to be able to fit me in until the end of April beginning of May.
Well I need to get the RSTB's welded up and built from the GB. However after that I plan to work on the traction bar design that I've been neglecting. It's proven to be a little more challenging because of how far my wheels turn into the wells with the control arms being so short. Makes it a little difficult to connection the bars to the control arms and still retain proper suspension geometry.
think of it this way, if you could build a one off subframe that would accept slightly modified aftermarket lca's from a vehicle of similar structure that already had a traction bar available on the after market, you'd have a lot less geometry to worry about, wouldnt you? I mean a subframe/cradle has no moving parts right? and all that would need changing is the ball joints to fit our knuckles, and then adapt the traction bar mounting beam to fix to the chassis?...
Wrong.
There is more to suspension geometry than just LCA placement. You can modify the control arms shape as much as you want as long as the length from center line pivot point of endlink to balljoint stay the same (they only see a straight line). As soon as you start lengthening or shortening, raising or lowering any chassis component without taking all things into consideration is when you have a mess. Even something as simple as moving where the steering rack mounts up or down in height can be detrimental.![]()
so custom lca's designed to take traction bars would be the best way to go then?
I hate that traction bars have the name they have. They should have named them Anti-Hop Bars, Stiffy Bars, or something more linear to their function. Sure there is "some" traction gained by minimizing wheel hop, but seriously...it's minimal on a higher hp FWD car. Spin, spin, spin 1st, 2nd, and 3rd and I can't wait to stick my finger in Mike's face and say nah nah, told ya so! :lol:
I can't remember completely, but I think FWD cars set the toe slightly outward because under torque load the tires want to toe in towards the center of the car...could be off a bit there, but the purpose of the traction bar on FWD is the attempt to minimize bushing flex, suspension slop, and unwanted control arm movement front and back by linking the A-arms to the frame. It's alot like a glorified sway bar only the bars directional path is front to back rather than up and down and the A-arms are not really "linked" together. By joining them to the frame in this manner the unwanted "flex" and/or toe in and out is stabalized, minimizing hop.
There really isn't a whole lot of "geometry" involved in building these so I don't know what Mike is talking about there, but there is the clearing of tires, axles, tie rods (in our case we luck out...rear tie rods), brakes, and other good stuff that could be in the way like he said. They just have to clear everything throughout suspension travel. Which is easier said than done.
...As for the geometry I was referring to the fact that you have to make sure you keep the mounting point of the bars in-line with the pivot point of the LCA as if you don't it will bind the suspension and cause large amounts of grief as in doing so you would basically need a variable length bar to compensate for the differences in length needed. As long as you mount it in such a fashion such that the pivot point is shared then the bar will essentially move as one with the LCA. This is easier said then done since there is all kinds of business going on between the available mounting point and the LCA. Couple that with the close proximity of the wheel/tire along with the transmission and subframe and it makes for some fun... But I like a good challenge. I just need to commit myself to it for a long enough time to resolve all the problems.
But hes not going to have tubular control arms, unless I missed something lately he is running the stock 4 bolt arms.
Also, I like the idea of solid subframe mounts, PRT has them and will make them.
