elraido
I kant speel
How's this thing coming along?
I believe the correct term is, "slowly."
Well I took a bit of a break, went on vacation down to Orlando, FL. Good timing anyway as I was waiting for some upgraded parts for my TIG torch. So as of right now I'm working on my TIG welding skills. When I feel I can put down a good weld consistently I'll knock out the last couple of pieces for the fuel filler tube. Then it's just a matter of putting together the car.
So, all the paint you wanted to do is done and you don't have to wait until spring when it warms up?![]()
im in orlando fl![]()
till when are you gonna be here?
Then I need to plant some corn to make my own ethanol and start refining my own oil which I will extract from a well I am going to build in my backyard. THEN I'll be ready to put this baby together and put it on the road.
Hope you don't mind me poking fun - this popped into my head when reading your update - just finish the damn thing already!![]()
::snip::
As for an update I'm pretty happy with my welds now. Although I need to find myself a good welding table. I also need to build myself a good heat sink and find a means of back feeding some argon gas to prevent some issues. So until I am able to get that situated I'm not going to be able to finish up the fuel system.
I've got a dual-stage regulator with hose you could borrow to dial down the backpurge pressure. A welding supplier should be able to hook you up with a Tee fitting to run two regulators off your bottle. Shoot me a PM if you're interested.![]()
There ya go! I know you've done quite a bit of welding, as it's been showcased in this and other threads...
Well I got it welded. Pretty happy with the results... after all it is only the 6th or 7th time I picked up a TIG torch. The bead is a bit big for what it is, but it will do. Need to clean it up and remove the excess material, but that hard part is finished.![]()
