I sent a message to
http://www.e-clec-tech.com/smpakits.html concerning their EL panels. Here is the email and their answer. It would seem if we can get sills with the SVT Contour cut outs, the EL panel could be put under it. The only problem would be the length of the panel, about 3 3/4" long. I guess 2 together could be used.
My email:
I'm thinking of cutting thin sheet aluminum to use as a sill plate for my car. I will cut the car's emblem out of the plate and plan to put a piece of EL panel under the plate to illuminate the cutout of the emblem. My questions are:
1. How thick is the EL panel? It appears to be relatively thin since the ad states it can be cut with scissors.
2. If it is thin enough, is the connector on the panel thin enough also? I would put a layer of electrical tape on the top and bottom of the connector to prevent it from shorting out on the plate or the car body. There is no movement of the sill plate so there would be no problem with chafing. I'm thinking this way the connector is on the end.
I suppose I could use it if the connector was on the side. That way the connector would not be under the sill.
If this works out, alot of people I know would be interested. Thanks in advance.
-Tom Hoyt
Their answer:
Hi,
That sounds like a great project!
EL panels are commonly used for that purpose.
They are as thin as paper, so you can just use a pair of scissors to cut them.
Yes, the connectors are very small as well. You can just solder wires to them to get the thinnest possible size.
There are many sets of connectors along the edge of each panel. You only need one set. So you can choose the place you want it to be and just remove the others.
Thanks
MJL
