Smalls
Addicted CEG'er
the fordcontour.org guys in ohio (dom and billy) do MPV swaps frequently iirc
I'm always a day late and a dollar short lol oh well maybe im the first to use the MPV UIM if not oh well they can roll like that in ohio but were in the sun shine state i'll just do it and be excited to be a lil differentthe fordcontour.org guys in ohio (dom and billy) do MPV swaps frequently iirc
That intake manifold is soooo big and ugly! :laugh:
yoy are corect he will source a taurus tb since the MPV and escape tbs are reversed therefore the cable goes the opposite way.
That plug is the throttle position sensor, I swapped the Escape TPS into the Taurus tb, but honestly I think you can just remove it and turn it around.Also my only concern is the plug that plugs into the Taurus tb is facing Inward and hits the mpv intake manifold when it's plugged in ... And to un plug it you need to unscrew the plug or take off the throttle body..
So your throttle cable pulls from the same side as the MPV tb did? That should be the opposite.
No, they only rotate one way. If you just reverse it and try to rotate the throttle body shaft you will break the sensor. There are a couple iterations of the TPS and I think you want one from an 04 taurus. I've got one that puts the connector towards the UIM and another that puts it away from the UIM but i'm not 100% sure which came off of what car as they were from the junkyard. I can say they were all taurus parts though.
