elraido
I kant speel
LivinSVT is the man, and this trans he built feels rock solid..
yes he is.
I started to developed a leak. It looks like oil coming from the AC compressor area. I am not sure though if it is a leak or if it oil dripping out of the radiator fins from the oil blowing out of the filter when the original motor was pulled.
It could be from the fittings at the block for the oil pressure sending unit connection or the oil pressure sensor. I'll get under there and take a look and let you guys know. Dripping or not, I am still happy
I also will be having custom fuel lines made for using the SVT fuel rail and injectors. That will probably be this winter so everything is ready to go for SZ '09.
Thanks ShoGo - No problem with the help. I can't do much over the phone, but more ideas are better.
I know I don't have a huge issue with the oil coming out, I just want it to stop so it doesn't make anything dirty. Oil pressure gauge sux though. Mine only goes to 100psi and I didn't know anything when I got these gauges, but luckily they were electrical not mechanical. My gauge has read down to 25 PSI at idle and usually runs at 80PSI on the highway and I am tapped into the block behind the ac compressor. I thought they were supposed to read lower than 80PSI when driving normally :shrug:. Oh well
It COULD be... but gauges can usually take a lot of abuse before they start reading wrong enough to matter.Could it be my gauge?
