todras
Pretty fly for a white guy *cowbell*
Mine reads the same as Fox's. I think 63 cruising. 80 something on cold start. Idle around 18. Mine is mechanical and is plumbed into my oil filter relocation setup.
I'm pretty sure that mine is tapped at the head. Reads 40 PSI cruising on the highway, 80 PSI cold idle, 8 psi hot idle.![]()
At cold start my gauge reads over 100psi while driving for a good 3-5 minutes, what does that mean....
I don't see a problem .... does the oil still have assembly fluid in it?
Near zero affect in my opinion. The ratio of assy grease to motor oil should be very small.ok assembly fluid is some thick stuff, that is going to increase the oil pressure because its thick. you need to see what the pressures are after you change the oil.
Too high of pressure can be a problem. There were a good number of late '90s Duratec failures due to sticking oil pump pressure relief. A real cold startup created enough pressure (it's a positive displacement pump) that the oil filter would burst. Never heard of any more issues after the pump was revised.
I'm pretty sure that's what started his whole 3L project in the first place. The oil filter burting anyways. Sandblasting residue blocking the relief valve?
Correct-o! The newly powder coated parts (everything) were sooo clean that I would personally lick the inside of any of them. Not that I did, but you know what I mean![]()
Now that I have the car jacked up again to fix the oil leak I noticed that the brake lines are also "seeping" in the front. Should I put pipe tape on the threads of the hardlines where they meet the flex line? Just little stuff to take care of before the snow flies :throwup:......
brake lines dont use the threads to seal, they use the flare. Teflon tape will do nothing but hurt you. you shouldnt have to crank on them either. if they are leaking, its probably due to a poor flare on the hardline.
Sorry to get a little off topic, or get away from your thread, just wanted to explain why I am checking out your thread. Have a good one!
I JUST sourced one for $400! This is awesome, I can't wait to pop it in and start fixing engine codes!Hey, no problem and thanks for reading. I know there is a lot of info in this thread so it is hard to read up on if you don't have the time.
Like you said, it will probably be cheaper/easier to source a 3L and go that route. You can do it because I am probably the least trained on any motor work ever until this and I could do it. Basic tools and a will to want to learn and do it yourself. If the car is busted already you don't have anything to loose right? Go for it.
Hahaha, thanks!!!Lies! Watch out for sneaky Canadians invading posts.
