elraido
I kant speel
what is the point of that mod?
i would suggest removing the heads for the porting , since you already have to change the mount , the cost of a couple head gaskets and head bolts is worth the piece of mind of knowing there is no metal shavings in the engine, much easier to port the heads on a bench anyway
p.s. dont forget the exhaust ports
While bolting it in after grinding down the flanges a little to get it to fit in the bracket easier I noticed the megafuse was fried.
The best thing a person can do to avoid problems like this is to just take your time assembling. And you're still going to miss something. It happens to everyone. Just hope it's nothing big (like a pulse wheel or cam timing).
Because it was there :shrug:.
Who thinks I should remove it? What about the 2 tubes coming off it that goes to the DPFE sensor? Do I get rid of the DPFE sensor too?
This car pisses me off because I drive it for very little and then something else goes wrong again.
