Some Pics and Questions
Okay, So the blower has been running for about 800Km and so far so good. I had a slight misalignment and I had to put a couple of spacers in between the pulley and the mount assembly. Have a look at these 4 pictures and let me know if you have any questions.
Here you will see the Air intake making the corkscrew down into the blower. It translates a 3.25" K&N air filter into a 3" pipe to a 4" inlet at the blower. It's made up of parts from silicone intakes, ebay and princess auto (t-bolt clamps)
Just above the maf, you will see the aluminum BOV and the 64 tooth pulley.
Just above the KN filter, you can see the 2.5" into the Throttle body. - this needs to be upgraded to at least 2.75" to match the TB. The outlet of the blower is 3" so this is really a temporary pipe.
http://i110.photobucket.com/albums/n91/pmaropak/P7090077.jpg
Here you can see the top view, and boy is she dirty!!! You can just get a glimpse of the cog drive. I chose this to keep the tension down on the pressed on water pump pulley that keeps the whole drive assembly moving.
http://i110.photobucket.com/albums/n91/pmaropak/P7090075.jpg
And here is my f-up with the spacing, as you can see that pulley should fit right into the pulley mount, but alas, I was off by 1/8" and I needed to move it over. Sorry about the focus.
http://i110.photobucket.com/albums/n91/pmaropak/P7090076.jpg
Here is where I need some help. If you follow the blue line back from the BOV, to a t intersection, the line off to the right goes to my boost guage sender. Off to the left, if connects to the hard lines off the Upper intake manifold. Here is my problem, I'm not showing any boost!!! I have a lot of play power, there is no question there is a significant performance increase, however no boost on the gauge....
So, I;m asking where should I be connecting the pressure line to generate boost? Or have I miscalculated my boost expectations?? The impeller will be spinning at about 36,000 when I'm running at 6700 rpms I was expecting about 5-6lbs off my powerdyne bd11.
Funny story, I had really given her the gas (in a low gear so not to speed) but I blew the BOV tube off the valve, and Whooowee! I thought someone threw a nut into my piston! I got a MAF does not match TPS code, I had a crap, noticed the tube, reattached and cleared the code - everyting ire!
http://i110.photobucket.com/albums/n91/pmaropak/P7090078.jpg
It sure is fun! I'll have to get a tune and a dyno, but I'm in no hurry. I have some slight modifications, a 72 tooth drive pulley, a 2.75" charge air pipe.
