Undo axle nut, remove pinch bolt for b-joint, undo tie rod and end link, grab 3' pry bar and pry down releasing b-joint from knuckle. Loosen top strut nut so susp. can move. Use air chisel to drive axle out of hub. Unbolt control arms. Takes about 25 minutes for pass. side. Driver is longer since you have to cut the 2 forward bolts under the trans. Insert new bolts upside down.
how to: complete.
lol
your PCV valve probably isnt sealing fully and your pressurizing the crankcase. also, where are the valve cover vents tied into the intake?
anybody have an idea how much it would cost to bolt a rotax c15 up where the AC pump is?
I think that would be a great setup.
so I guess a c30-74 will fit, 5.7 in diameter, 7.1 in length.
any body know the size of the ac pump in inches? I'm pretty sure it's bigger than 6X7...
also, can a rotrex be driven directly off the Acc. belt? it looks like it's a serpentine pully on the head unit to me.
