PHilly
Crank pulley on the 3L is stuck like a motha focka, any ideas? Tried an impact gun and by hand....
I realize that, thank you.you realize the crank pulley isnt reverse threaded. its a two piece design you have to crack the outer pulley (you cannot hold back on the hex shaped inner piece, as its all one piece!) get that off and under that pulley is the actual crank damper bolt, which should be reverse threaded.
How about you come out here and I'll buy you some pizza and a lap dance.... uhhhhh what?Oh Jon......
oh lord, I've done two now and never had a problem.
seems to me, the problem with these is operator error, not that they are tough.
although, after you break your tools tightening it, then it's going to be a PITA....
man you are pretty cocky now that your 3L is running. operator error like your coil pack?
I've done 4 3L's, 3 came off no problem, one was a huge pain. it isnt operator error, some are tight.
one trick i used was i clamped vice grips on the harmonic balancer at about the 11 o'clock position radially outwards, and the vice grips would wedge against the timing mark protrusion on the timing cover to hold the crank while i loosened it. I have had better luck with that than holding the flexplate.
lmao my thoughts exactly!Banned again?:nonono:
from what i understand and i may be wrong but the 2.5 and 3.0 pistons are the same or close to it and the stroke of the 3.0 is what gives it the bigger displacement. I think it would be fine with either gasket but dont quote me on that.can i say as i havent seen it mentioned anywhere, but im thinking of doing a hybrid build motor, in which i take my 3.0 engine block and crank, and take the crank off, lighten and balance it, then add diamond racing forged pistons with forged rods and use the arp bolts on the rod caps, as well as on the heads and then mate this up to my svt heads and cams, now i want to order some more performance headgaskets, but im a bit confused at this one, which headgasket would i use? The 2.5 or the 3.0??
I would hazzard a guess at using the 3.0 because of the size of the piston bore so i guess in theory the 2.5 gasket holes where the pistons are would be smaller than the bore of the 3.0, where as using the 3.0 headgaskets would not have this problem that i can only think off,
any info on this would be appreciated, and good luck with your build![]()
are u done yet?
