SoopaCooga
Noble/Rossion is enough for me to choose from.![]()
ain't that the truth! now if i could only find one wrecked... :crazy:
Sold on ebay for $35K.![]()
That would have sold for $50K if it was silver. :laugh:
Probably...that picture doesnt do it justice. It really is a beautiful color yellow.
Not sure if this pic is going to work, but if it doesnt just click the link.
Are you willing to produce/sell the adapter plate? What are you doing for a flywheel and clutch?
:shrug::help:
Yes i will be selling an adapter kit I also did a spacer for the flywheel where we reworked the mustang flywheel to match the bolt pattern. We lightened the flywheel up and rebalanced the flywheel to a neutral balance. I will try to remember to post some pics. Joey
Joey, did you sell your Mustang eaton swap design to Torqtech?
Look into Astro Performance for very nice T5s, I think the rotating mass of the 3550/TKO/T56 is not worth it for this application, plus the T5 shifts better in high rpms (trust me I've had everyone listed above).Cool! So is this along the same lines as David Godfrey's conversion? An adapter plate and a mod'd flywheel?
I honestly wasn't looking forward to the fab work. It's probably not as bad as I was thinking, but I never did get a T5, a bellhousing, FW and a starter to even begin to figure out how to get everything to get along with our lowly Duratec. Did you ever look at TKO, 3550 or the T56 as an alternative that can handle a bit more torque in OEM form?
Good enough.
I've only looked at these transmissions when I wanted to build up a first generation Mustang fastback with a TT & modern drivetrain.
thats the exact project i am just about to start
It'd be an awesome car, that's for sure! After seeing that I'd have to switch the front suspension to an aftermarket setup or hack the coil/strut/shock towers (whatever you want to call them) to get the proper clearance for the exhaust piping...... I decided to finish the projects I already have first :shrug:
Are you going to document your build up? :drool:
