zorrex
Enjoys the Abuse
Should be nice most of the day Sunday... plus I am installing Dr.Cross's MSDS Headers, so feel free to swing by if you like...
Oooo more headers! I get out of work at 1, this may be a thought :crazy:
O'man I just messed up my keyboard from frapping so hard at the pictures :crazy:
Is that anything like fapping? Sounds like you need pointers.
When are we gonna see some dyno runs:laugh:?
Be fun to see it dyno at Carlisle. Imagine the looks. Sweet turbo Escort!
I reset the low and high speed fan turn on points, the low speed now comes on at 200 degrees and the high at 212. The coolant temp the whole day in the 80 degree heat was 202~204 and the oil temp stay right around 212~215. Ran great all day.
My stock oil temp is 210-212 cruising. Very nice for a turbo.
well I found out yesterday that if you get on it hard for a length of time the oil temp will go up of course .... went up to around 240.
well, I never had a oil temp gauge in the mustang, but both turbos were oil-cooled and I didn't have an oil-cooler. If I was a betting man, I would bet that I had oil temps up over 300 many times.
hmmmm, now why did I blow up 3 engines with that turbo setup........
no dyno sheets or other info as of this time.
I seem to have a problem with my dpfe sensor, the hoses don't want to stay on when I crank it up to 8 psi. I found out frinday morning that both hoses just dissappeared. I asl had the larger one poping off all weekend. Finally this morning it blew off and I believe took part of the plastic housing with it as I was getting on the highway.
other then that vs a 2.5 SVT turbo at 6 psi and a 3L with NPG LIM mod both had to use 4th gear to match me in 5th while putting it to the floor ...
