TUFTOUR
^I was wondering if anyone would notice...
and thanks! :laugh:
thanks! ^no, it looks lighter in the photo than what it does in person...it's not a perfect match, but it is the tan color for the Contour interior.
Lookth Nithe
(Please wait while I pick up jaw from floor)
Ok, good. With that said, Looks Nice! :laugh:
x2I want one.
and the ultra rare, elusive shots of the fender cuts to make the intake pipe fit...there you go, Brian...![]()
^sounds like sour grapes...I would be too if I had sold one of the best cars known in CEG![]()
also the fitting on the compressor side of the turbo, do you know what that is for or what gets connected to it?
I saw that and I'm not sure either...I'm assuming it taps into the maze of vacumm/boost lines at some point :shrug:
Some questions: How much of a gap did you leave between your intercooler and the radiator? Did you mount the PS cooler the same way I did? It wasn't reallly clear in the instructions and I haven't had a chance to talk to Joey to make sure...
And thanks everyone for the compliments!![]()
Man how Paul keeps his stuff looking REALLY FRESH and still Stock Looking..
- amyn
I forget, but there is space. I have the power steering cooler up under the IC but I didn't use those little blocks, but then again that is also appears that is why I coud only mount the cooler with one bolt. I have some smalled bolts, 4 of them but no nuts to go along with them. plus the bolts that I took where for the IC are to short to go through those blocks and where to large for the OC brackets. The way I have it now it just fits inside the bumper. I need to re-bend the brackets. I just put a bend in them and then I pushed the intercooler up as far as I could get it.
I'll get some real pics tomorrow.
also what are the radiator fan spacers?
the aluminum blocks with two holes drilled is for the lower radiator support bracket. When you put the spacers between the raidator and the frame it will allow the 2" pipe going to the intercooler more room for installation. Paul did find another good use for the blocks but the U shaperd brackets were for the PS cooler where it clamps it down but now that he did the install using the blocks I think it looks very good also. Joey
