svtfixer
you can use any 6 rib. go look theres a whole bunch of them.
Ive been thinking about your coupler upgrade you did, ill have to look at my unit when it arrives...
I welcome any vortechers advice on things you did on your install. svtfixer,jaged, 99mystique, ect.
My Objective is to do this once and not change my mind too much like i do, that gets really expensive. Reliability is #1 (for a contour)
This is sort of a mental dump and grocery list, please add your 2 cents.
[Cars current state]
'04 Stock 3L Bottom end with SVT Cams '35k on motor. 5k on the build.
'08 revision escape oil pan
Portmatched to big bore gutted LIM '99 Taurus UIM pnp'ed stock svt tb, remote iac egr/dpfe dellete
No A/C PS cooler delete.
Weapon R Headers to Truduals
255lph TRE fuel pump '24lb injectors
Built trans
Mocal Oilcooler in place of P/S cooler
Mini drycell battery.
Tweecer tuned
12lb lightened flywheel. Clutchnet Organic disc, Stage 3 Pressure plate. Should be good for north of 400tq
I think thats all that will serious affect anything...
[Grocery list]
Pull engine for install?
Vortech spec front header. Coat? $190 Wrap both headers.
Spark plugs. which?
Oil? Yes. What weight?
Injectors. EV1 42lb 4 pintle $250~
headunit rebuild. DIY? or send out?
Belt size with No A/C? account for smaller pully on HO alt..
MAF.. Stock sufficient? Run a MAFia? Run a 80mm+?
ADC intercooler... how much psi drop?
Bosch Lightning water pump, how to wire..?
heat exchanger behind front grill where hood latch is? How big?
Where to put battery... Trunk? Last resort. Relocate fuse box to fender? put battery where fusebox is?
Autometer Phantom Boost Gauge
Pulley size.......... How much boost do i want, take in account for psi drop on intercooler. 10? 9? 8? 7?
[The Needs]
Need to do inventory on incomplete vortech kit i have, things i know i need;
A •••• ton of fittings, nuts, bolts, washers, hose barbs and vacuum hose
radiator spacers.
The plastic inlet to the head unit.
lots of silicone intake couplers and clamps
AN hose for feed and return.
Brapple, You have transitions going to your maf, any issues with that?
Another hurdle is i am missing the 3.5" plastic inlet pipe, turns out vortech no longer makes it, If jt can't find it, going to need a solution. .
