Lack of home welder is not helping. I'm more in the middle of waiting for a friend of a friend to let me borrow it.
My coilovers are just about done, need a few bits on those before i drop them in.
GET A SHORTER BELT. ••••in A
But if you are getting it pre set up i wouldn't worry. Like i said i have never set up a machine for flux core so take what i say with a grain of salt.
2 1/4" radiator spacers on both sides. Gives you some cool space between the engine and the fan assembly. .
great to hear your buddy helped get you moving forward.Car is pretty much back together thanks to the help of svt_0611. .
i'm in a simillar position. I have a basic tune to flash to the PCM but i couldn't get the guy to sound too confident about how much i can drive on the tune. He said drive it, but don't go revving it right up. Where are you up to.. is a basic tune how you are getting to idle ? ...G.After welding, tuning will be the only thing that keeps it from running, i think i can get it to at least idle, but in all honesty i don't have any confidence tuning for boostWhich will likely prevent me from driving it this year. Bummer.
a few minor tweeks to miss the oil cooler and sump pan and a couple of nuts welded to the tubes for an OEM heatshield and the vortech header would have been perfect.Probably could run a non vortech header.
well having your car back in one piece means you can at least run the engine and move the car around over the coming months.Yeah under no boost will be fine. Got the maf slope done and just need to adjust for bigger injectors
