pics work for me. Its hot sects
ok that is weird, they didn't work at home but they did here at work, now thats backwards ...
How is the turbo going to be set up? Is it run off of the front exhaust headder only, or are both banks tied into the turbo? Also, is the kit comming with an adjustable boost controller, and if not, do you know what the stock boost will be?
You are pulling 364hp with just 4lbs? Impressive.
My 3.0l has forged pistons and rods and has 10,000 on it at the most. What would be a good psi to run on this without too much worry of premature engine failure?
How adjustable is the wastegate? 4-8psi, or liberally variable? I hope my questions aren't too analitical, I just like to know all the details before I buy something. So right now it is looking to be a turbo, intercooler, downpipe, and tuned chip in the package with the mounting hardware, correct? Does the buyer do his own intake system?
Are you anticipating that the kit will bolt onto the factory flex pipe or some other point along the exhaust?
Both banks.
Im going to take a wild guess and say that the kit will not come with an adjustable boost controller. The wastegate does come with a preset spring. As to what you decide to do after you buy the kit is up to you. If they make a boost controller an option or standard, then people will want to upgrade to a dual stage or an electronic boost controller, or people will want to cut it out to save money. Im guessing small stuff like that that isn't neccessary will just complicate the cost of the kit, since people will always be wanting to change their mind. Its probably just easier to let the owner do what they want with the boost controller.
Btw, my Tial Wastegate from ADC came standard with a 4 psi spring and trust me, I still have traction issues with that much boost. Tom was making nearly 300 whp on 4.75 psi with his 3.0L.![]()
lol no, i do have a boost controller. That was at 16 psi with an uncompleted pull at 4,700 rpms. Your vortech is non intercooled right? If you had a T3/T4 lets say, I dont think I would go much higher than 8-10 psi.
What size are the T3/T4s? I am used to Mitsubishi turbos. I run an evo 3 16g turbo on my laser with 15psi. Two axles and a clutch later I am thinking it is a little overkill, but what a ride! My laser is the main reason I want to swap my Vortech for a turbo set-up.
Hopefully there isn't a thread on this already, but I noticed your statement about 3" exhaust for those "who need it" What exactly determines the need for 3"? Is it having a 3L block?
I've always wondered if it was okay to upgrade to 3" without affecting the engine? I've heard there needs to be certain amounts of back pressure on the heads to keep from messing them up, or doing bad things to them. Is that myth or fact? Been watching this thread contently, so I hope this little off topic stitch doesn't cause too much fuss.
Thanks.
