striker2
Official CEG Vendor
for the average CEGer yes.
Personally, assuming it's in good shape, I'd take a duratec over the Zetec in the Contour. My Focus has a bit done to it, including the exhaust and intake, and I have to say, despite being a bit faster than my old Duratec MTX Tour, it sounds like ass in comparisson. Duratecs are heavenly with nothing more than an intake, add the exhaust and its golden.
A topic like this is like asking which religion is better. It's all a matter of opinion.
BP
Come over here and kick me.:nonono:They have their place, and that place is generally not modification. If you want to modify your Zetec, first off make sure it's not an ATX (I will personally come and kick you in the nuts if you think modding an ATX Contour is worthwhile, unless you have circumstances that would prevent you from driving a manual, I understand). And secondly don't try and convince yourself that the Zetec is somehow secretly a superior platform. Admit that it's inferior, but you're modding it because of either a desire to be unique or current circumstances.
But like Button said it is a matter of opinion.:shrug:
Hence my original statment
For about the same amount of money you can have about the same amount of power out of either one. however it takes quite a bit of knowledge, skills and tools to be able to do so to the zetec. if you have that knowledge (the average CEGer does not) then you can spend about 4-5k (including initial purchase) on a MTX zetec and make it have at least 170hp easily(standard duratech) and over 200hp with FI. Plus with the zetec you dont have the issues that you do with the duratech (i.e. water pump, IMRC, moosing, throttle hang, etc.) since most of CEG doesnt have the knowledge to do that they choose the duratech.
so if the question is which one should you buy and you have the knowledge and tools to do so then i say go with the zetec. if you dont have the knowledge and just want more power now then go with the duratech.
The Zetec isn't the inferior car....
Just because a car has a smaller engine doesn't mean that it is inferior....THAT is my opinion.So is that your opinion? Every situation is different. Different people get different deals on different parts, making individual examples not very helpful. I *could* happen to find an SVT with a blown engine at a junkyard for $1000 and I *could* rip a 3.0 out of a rolled '01 Sable for like $300, giving me 200/200 for $1300 at the simplest level.
sure they do, that's why you can have a 400whp honda with only 205ftlbs of torque?
and you comparing simalar modded zetecs vs duratecs is retarded, the motor that started out with more HP will have more hp at the end, Mod a SVT zetec (170hp) vs a non-svt duratec and then get back to us.
SVT zetec came in the Focus SVT. I beleive you guy's never got it. It's basically a post-98 Contour Zetec, with VCT on the intake cam instead of exhaust, dual stage intake manifold and a couple other things.Just perusing the posts, but I gotta ask this question.....There is a SVT zetec? ..... and would it be similar to the non SVT version with just a different head and exhaust, or ???? :shocked:
Thats cause they're pushing 20lbs of boost out of a turbo that was designed for only 10lbs. they dont have enough airflow to make more torque.
so i guess you dont like either of these:
KerryKools exhaust -SVT exhaust on a zetec
My exhaust -custom exhaust on a zetec
The Zetec isn't the inferior car....it is cheaper. So everyone getting into Zetecs didn't have to money to waste on a SVT which means less money to mod with.
My Zetec ATX lasted longer than most Duratecs. If you don't believe me, go look how many Duratecs needed to be replaced (which started the whole 3L swap).Ideally I would have chosen a ZETEC MTX but I worked with what I had. But I still would have gotten a Zetec.
For about $5k will get you 200/200 on a Duratec.....I only spent $3k for my small supercharger setup on low boost putting out 160 at the wheels with the ATX sucking out more power. With another $2k wonder what would have happened?:troutslap:
hector put down 160whp , with his atx thats prolly 220hp.I've seen vortech superchargers for sell for $1500 for duratecs. They'll put out a lot more than 160hp. Well heck, my svt cost less than your supercharger did and puts out more than 160hp stock.
It is not cheaper because he had to get another car. Like I said before you work with what you have. I put down 160 WHP with an ATX. With a MTX numbers would have been the same as modded 2.5 SVTs. Like I said, supercharger only cost me $1900 plus everything to have it run right.I believe Kremit put down more than 160whp stock, too.. so it would still have been the cheaper route to that power level.
My SVT cost less than my zetec did. At this point in time, duratecs/SVTs are cheap enough to start out with them for modifying. Obviously it's not always best to just work with what you have. Sometimes you have to get another car, right?It is not cheaper because he had to get another car. Like I said before you work with what you have. I put down 160 WHP with an ATX. With a MTX numbers would have been the same as modded 2.5 SVTs. Like I said, supercharger only cost me $1900 plus everything to have it run right.
Kremit, there is a reason why you can get a Vortec for the SVT for $1500....it is unreliable.
