iBrent
That's what I don't get though. I datalogged the car and when it was bucking, it was pulling 24º (yes that's right 24º) of timing. I read on NECO that some people have had really good luck replacing the coil (because I guess the Cougar coils are prone to cracking) so I think I will start there, then go to the knock sensor.
I was going to suggest checking the coil. If you have a multimeter you can check and see if the coil is in spec by measuring the resistance between the different points. The autozone website has the specs.
