james1767
Hey all - wanted to chime in here - my 2000 CSVT has a buck that occurs in 3rd gear between 2K and 3K rpm, just like t.lynn.c (this is the 1st time I've heard someone describe it as exactly as I'm experiencing). Here's my story - I replaced my fuel pump with the updated Ford PFS289 pump as a precaution - no symptoms before the fuel pump install, that I can recall. Around the time I put in the replacement pump (this is the one that requires cutting the ring in the bottom of the tank - all went well during the install), I noticed the slight hesitation in 3rd gear between 2K - 3K rpm. Seemed to be getting a bit worse (or perhaps I was getting more hypersensitive to it). Pump lasted about 10K miles and quit working on me one day in an intersection. I then installed a 2nd Motorcraft pump, which is currently in the car. Still has the buck/hesitation in 3rd gear. Stone cold, the car runs fine - smooth acceleration. Shortly thereafter, the buck starts - it's more severe some days than others. I'm so frustrated with this, also wondering whether this pump is going to fail again. I've tried pretty much everything else - new Motorcraft wires and OEM plugs, cleaned MAF, switched fuel pump relays, checked fuel pump driver module for functionality, checked fuel pump wiring, etc. Engine coolant temp sensor is fairly new. I'm seriously thinking of getting a used fuel tank that still has the old style pump in it and installing that just to see if the problem goes away. I did not install the flapper valve mod when I replaced the pump, since I did the pump install by cutting the floor rather than removing the tank - wouldn't think that should make a difference? Anyway - just food for thought - everyone that's having this problem - do you know if you have the updated Motorcraft pump or the original style pump? I should also say - I have the P0420 code for precats so the check-engine light is on for that, but every time I run a scan on it, it's the only code I'm getting, so I'm never getting actual misfire codes despite the buck/hesitation I'm experiencing. So the P0420 does complicate my situation a bit, as it could be maybe causing some driveability problems, but I thought others have driven around with this code and MIL eliminators for many miles with no driveability problems.
