You aren't supposed to "lift" these engines out of the car. You are supposed to drop the sub frame.
older year shop manuals say to drop the enigne out the bottom. the newer shop manuals say to pull the engine out the top.
pulling from the top is easier without a lift. also it helps to not have to remove the subframe as the bolts often freeze up and cause headaches.
