3l Contour Registry
Svt 3.0l
Svt 3.0l
2000 SVT Black/prairie
80k on body
1500 miles on 05 Taurus 3.0L swap; ported IM, stock cams SVT ECU
factory (leaky) exhaust, clutch
KKM intake ; motorsport wires
2000 SVT T-Red/Tan
88k on car
5k on Ported 3l wtih svt intakes, cams
2004 taurus 3l with 24k
Bat intake, optimized tb, msds headers, bat y-pipe, bassani, solid roll-restrictors, stock tranny with torsen, untuned and running strong...
98 176k
SVT
05 Sable 23K
Running
Aircougar performance swap(Greg,Roger,Brian and some more Greg)
Ported 3L W/Bugzuki plates SVT Cammed
MSDS Headers~MSDS Y-pipe W/Mils
Torsen~Exide/Luk clutch~Fidenza FW
Pole120 Rear RR~ES Front RR
19lb Ford R injectors~Ford R Wires
TruBendz Hi-flow Cat~Center Magnaflow to Dual Bosal's
Custom CAI
-1998 SVTC MNB/SF 114k miles before second 2.5 went
-04 Taurus 3L 5k
-running, but not driving-see below
-swap went well with advice from BrApple. I took 4 months to do it working on it only a couple days per week. Took the time to replace gaskets and clean things up a bit. It started and drove just fine, but within 24 hours I blew up the differential because I did not have the funds at the time to get a LSD installed or have the trans built up. I knew of the dangers of not having the trans built, but took the chance because the car had been down for over a year already. I WOULD HIGHLY RECOMMEND getting an LSD insalled or having the trans built because it won't last long without it! Swap was started at the beginning of April 2008 and completed end of July 2008
MODS: K&N RU-3530 with Mirko MAF adapter, MDSD Headers/Y-Pipe, stock exhaust from the Y-Pipe back (for now), Ported 3L with 3L cams, SVT intakes with Bugzuki plates, Painted engine block with high temp silver paint, powdercoated UIM and valve covers, Ford Racing 9mm wires, Autolite double plat. plugs, Tuned by NPG.
-1999 contour silver frost 300,000kms
-svt
-3L 2004 taurus
-running
-bought it not running got the pats programed, finished alot of odds and ends, 3 new wheel bearings and rims and tires.
I have two 3L contours, And I can defininetely feel the difference in the two cars when driving
-98 Mystique
-non-svt
-unknown
-running
-on it's 2nd 3L first on died due to a spun bearing. That one was a hybrid
-motor with 2.5 heads. This latest one is a portmatched with 3L cams and chains. Running with a stock SVT exhaust.
98 SVT
SVT upper
3L taurus motor I don't remember milage of year or donor car
Running strong with port matched SVT heads and cams.
This car has not been tuned the only other difference is my SVT has headers.
So here is a compiled list so far (feel free to add to or correct as needed):
Name - Car @ mileage - engine w/ mileage - date complete
blu_fuz - 1995 SE @ 212K - 2005 Taurus 3L w/ 18K
SVT1480 - 2000 SVT @ 126K - 2002 Sable 3L w/16k
BrApple - 1999 SeVT @ 95K - 2004 3L w/17K
LilCE - 1998.5 SVT @ 124K - 2005 Taurus 3L w/44K
SVT Snob - 1998.5 SVT @ 206Kkm - 2003 Escape 3L
SVT Snob - 1998.5 SVT @ 200Kkm - 2004 Taurus 3L w/20K
98ContourSVT - 1998 SVT @ 184K - 2001 Escape 3L w/80K
KyleQ - 2000 SVT @ 125K - 2004 Taurus 3L w/37K
Marky - 1998 SVT @ 81K - 2002 3L w/20K
Black98CSVT - 1998 SVT - 2005 Escape 3L
Black98CSVT - 1998 SVT - 2001 Tauruse 3L w/10K
TX00SVT - 2000 SVT @ 56K - 2001 Taurus 3L
elraido - 1999 SVT @ - 2004 Sable 3L w/20K
ryanblackSVT - 2000 SVT @ 81K - Taurus 3L w/6K
juspifool - 1998 SVT @ 68K - 2004 Taurus 3L w/5K
Bugzuki - 1998 SVT @ 118K - 2003 Sable 3L w/3K - 3/07
kscontourkid - 1999 SE Sport @ 140K - 1998 3L hybrid - 11/07
PurpleMystique - 1999 SVT @ 83K - 2001 Taurus 3L w/60K
BlackCoog - 1999 SVT - 2002 Sable 3L w/30K
DemonSVT - 2000 SVT - 2002 3L - #1
wontgrowup - 2000 SVT @ 80K - 2005 Taurus 3L w/1.5K
95Mike - 2000 SVT @ 88K - 2004 Taurus 3L w/24K
SVT Loki - 1998 SVT @ 176K - 2005 Sable 3L w/23K
Frosty - 1998 SVT @ 114K - 2004 Taurus 3L w/5K
Fairlayin - 1999 SVT @ 300Kkm - 2004 Taurus 3L
ctmystique - 1998 Mystique - 3L
ctmystique - 1998 SVT - Taurus 3L
** This list is not meant to stop you from posting more about your car **
1998 SVT 156,XXX miles
Full 04 Taurus (i.e. 3L cams, heads, etc.), currently with 56,XXX miles,
EGR blocked off, Stock Taurus 24lb injectors, MSDS Headers, Test Pipe, TruBendz 2.5, 1x large resonator and 2x small mufflers.
Spec Stage 1 Clutch
Fidanza flywheel
Stock suspension
Battery relocated
Short Ram CAI, no heat shield
Tuned for 24lb injectors but need more work to get 100% correct.
It runs, but there are few things that need to be ironed out, like an IAC CEL as well as some other misc. things. I am thinking of hooking up the EGR but I am not sure about that yet. It needs to be running correctly before I think about doing that.
98 E0 SVT black.
180k on the clock
10k on engine
2004 Sable 3L
3L cams
2005 Taurus upper intake
Custom fuel rail
NPG fuel rail mod
Torsen Diff
Clutchnet.com Custom 6 puck disc ("red" rating)
Spec pressure plate
Pro-flow 75mm MAF
mustang 65MM TB
MSD dis-4 ignition
Mazda 6 CAI
WR headers
WR y pipe
Full 2.5" exhaust
many more mods.
previous WHP was 205/190, this is the second 3L for this car, however.
1995 SE
147,000 Miles
Running!
2004/2005 Taurus 3.0L Full Install w/COP
MSD Headers
Trubendz Y Pipe
Trubendz 2.5 Magnaflow Catback modified for one outlet
75mm Proflow MAF
Open filter
65mm Mustang TB (not in photo yet)
DMD
NGK Iridiums
SVT Radiator and oil cooler
Poly roll resistor and stab o shock
Torsen T2
Fidanza
BAT and Eibach Suspension with all poly available
SVT brakes
Super Chip from the CTA Motorsports Project SE
Next: Cold Air
Later: Remove heads and thoroughly port and polish
Tips/Comments:
This 2004/2005 Intake eliminates so many connections!!! It's clean and awesomely smooth. For the first time in 4 motors this car idles rock solid.
Turbo_Fox - 1998 SVT @ 97K - 2004 Taurus 3L w/7K
ported 3L, SVT cams, bugzuki plates, ST220 valvesprings, clevite rod bearings
3L Sa2ah!
3L Sa2ah!
We can officially add Sa2ah to this list!!! No CELs, mint idle, awesome start up, incredible throttle response. AMAZING POWER!
60K on the 3L engine....and Sa2ah can fill in the rest of the stuff for her registry. :D
1999 SVT Contour
@ 56k miles 01 3L w/ 99 3L heads and custom cut SVT cams.
Electric waterpump
SVT LIM, SVT UIM, SVT TB.
DYNOED 180FWHP.
@ 80k miles 03 3L w/ " kinger n/a cut heads"
ST200 titanium valve springs
SVT cams
SVT LIM
SVT UIM
SVT TB ported by buckshot
DMD
Fidanza
Spec stage 3+
Quaife
Trubendz w/ magnaflow mufflers
ADC T-28 turbo kit.
Pre turbo w/ msds headers Dynoed 194 fwhp
1998 SVT Contour
03 FULL 3L @ 86K miles
stock
--1999 SVT 131,000
--2001 Taurus 3L hybrid 55,000 since swap
--running
--rod knock occurred at 45,000. Replaced bearings, polished crank, 10,000 miles with fingers crossed.
2000 SVT #1842 ~131,000
2004 Taurus ~46,000 Ported with Bugzucki plates 04 cams 04 pan/pickup
running - NO CEL's UNTUNED
SPEC Stage 2 Clutch USED (thankyou ceg)
SVT Diff 20k miles USED (thankyou Reebs)
Performance y-pipe stock headers
plain IMRC cover
yes sir it is all stock. :)
http://contour.org/ceg-vb/showthread.php?t=37314
1998.5 SVT ~ 110,000 miles
2004 Sable 3L ~ 34,000 miles ~ Port-Matched w/ Bugzuki Plates and SVT cams
Running ...
MSDS Headers, DMD, yo-dude Y-pipe, Trubendz Borla exhaust w/ Magnaflow resonators
AEM intake, Custom Cold Air Extension, Fidanza Flywheel, Torsen, SVT Clutch...
Untuned so far... 205 Hp and 183 Tq
1998.5 SVT w/ 128,000 mi.
Ported 3L, MSDS Headers, & BAT euro trans. w/ 8,000 mi
She's angry at me for driving her in -30, but the starter motor on my sable needs to get replaced. Just a few more days and you can go back and hibernate in the garage until May.
