troll96se
how much do new tanks go for? its one of the parts i havent run past my parts counter guy yet.
in a recent issue of Muscle Mustangs and Fast Fords they did a small article on adding 2 E85 pumps into the stock tank. check it out it was a good read.
I've been running the SIS (silicone intakes, frozen boost, ect) fuel lines and fittings for years along with many other parts.They are slightly difficult to work with yes because it's a compression pipe fitting, but the material and the seal is superior. The quality is fine. If the fuel components leak or fails it is end user error. I've bought 3 custom fuel line setups from them. Youll be happy with what you bought.
Another note... anyone looking to flare stainless steel lines... I highly recommend buying a really good flaring tool. I just picked up the Ridgid 41162 377 ratcheting flare tool. It widely received excellent reviews across the internet car forums. Hopefully the masses knew what they were talking about. Ridgid's website even stated that it is well suited for flaring steel and stainless steel lines. Typically the el cheapo flaring tools $50 or less are designed for soft materials like copper or aluminum.
You can have that junk. I'll stick to my Fedhill 007C Line Flaring Tool.![]()
...Maybe I should have asked you if I could borrow it before buying mine :laugh:
wanna make me some brake lines? lol
I think the lines for my accusump project are larger than that, I could double check tho. If they are the same size I would take them
This is what I was thinking.![]()
seems like a good option to make new door sill plates for the car as well. hmmmm
