blu_fuz
New Member Classroom vulture
Don't clutter this thread with "why is it taking so long" BS then.
I said what I said with a smile on my face as posted, just joking around. I am glad you can do what you do, and as fast as you can do it. Congratulations TRicker on your second 3L build :thumbsup:........
ANYWHO - I did paint the engine bay, the radiator support, AC drier, and coolant tank. Went and got all the fittings for installing the oil pressure sending unit as well. I put the AC system back together, and I also re-wrapped all the engine wire harness' and soldered in the 3L knock sensor.
I couldn't find any write up on which color wire goes with which, so I could use some clarification if anyone knows so I can fix it before the motor goes in.
I also go the "c"-clip out of the clutch line from the original TOB but the rest of the nipple is stuck in the fitting, how do I get that out
Is this correct:
Oil pressure gauge lines:
AC drier midnight red :drool: :
Is this correct:
