todras
Pretty fly for a white guy *cowbell*
From reading before even a DIY is around $230.
I had this huge thing typed up for everyone to read and my computer locked up :nonono: so you guys get the short end of the stick. This below sums it up.
1 ground wire from motor to chassis was needed. I turned the key with the coil unplugged and the gas pedal to the floor. Let it rev for about 10 seconds. Plugged the coil in, and......
IT'S ALIVE!
I am officially in the 3L club, boo ya!
Idle is perfect, and for the few seconds we let it run, all seemed well
I have a small drip from the fitting for the power steering pump, that's it for now..... I was shaking the entire time.
But for you guys, here is my first posted movie from our new camera I got for getting married!
Airknight was the first...many many years ago,probabaly back around 00-01. i'll be joining joe starting in mid october. can't wait to see more detailed pics. btw joe,what tps are you using? obd2? if so what order did you splice the wires,i'm having issues running the taurus tps on my 95,not sure if its the sensor of the order of my wires.Wow this car is freaking amazing, definitely one of the most unique builds on CEG, and maybe anywhere. Has anyone else even attempted to make a 3L 1995 Contour?
Also, I don't know who else culd have pulled off the color scheme of purple with yellow accessories... Anyone else would have made it look ricy, but this car doesn't. Plus it's a beast.
Awesome car.
Awesome car.
Yep, they were lubed at the shop when they did the inspect/install. The ticking was because of lack of oil on the top end from a lifter. The cams and followers were lubed when I had the valve covers off when the motor was still at my place before I took it to the shop. Everything is ok man, don't scare me like that.........
It only ticked for 3-4 seconds, I had more ticking on my old motor when it was still alive.......
Thanks though.... did the video seem to show that it was running correctly and was that short bit of ticking ok?
A2Steve threw a full '01 in a '95 Mystique. It even had an ATX. I've posted many pics of it over the years.
I am not sure how many '95s are 3L right now. I think 3ish???? Mosh is a '95 3L. Then there is mine, and I am not sure who else is out there. A few '96 3Ls: rkneeshaw, beyondloadedse, a few others...... but again those are OBD2 systems.
