ctmystique
If the wheels are spinning slowly and you can stop them easily I wouldn't worry about that. I believe that is not uncommon.
I'd leave the clutch and trans alone. Change the oil since it has assembly lube.
Or dyno the car first, that whay they can get an accurate measure of A/F throughout your rpm range. So they will have more to work with when dialing in your tune.Yah, that's what they told me at the motor shop.
I will def. change the oil and if the clutch doesn't feel right, I might bleed that again, but it feels good now. Trans is pretty much all new, so I will go out 15K on it and change that fluid too. Can't hurt.
What about my A/F, should I continue to drive it with moderate to low fuel injection? Should I just call up nautilis to get a chip burned befrore a dyno?
I'll keep trying...What about my A/F, should I continue to drive it with moderate to low fuel injection? Should I just call up nautilis to get a chip burned befrore a dyno?
I'll keep trying...
Your A/F gauge is meaningless at anything other than WOT.
Don't even bother looking at your gauge when you're not at WOT, until you understand your PCM's fuel strategy during closed loop operation.
Doesn't a stock 3L come with 21 lb injectors? If so I don't see how 17 lbers would be enough.
This is how my 95 connects to a 98 fuel rail:
Rail End:
Rigid/Car End:
