svt_fomoco
Let us know what parts you are going to powder coat and show pics.
Another porting suggestion.
Remove the 3L cams and put the 3L valve covers back on before porting. This will ensure that all the valves are closed. If cams are left in, some of the intake and exhaust valves will be partially open due to the cam lobes. Even with plugging them and grease I would worry a bit. Hell, I would actually remove cams, and still use paper towel and grease + a vac.
Stuff some paper towel or shop rags in spark plug tubes and anywhere else you don't want metal shavings. When I did it, aluminum dust was EVERYWHERE!!!
Hey Blu, I am actually just about done with this same project! A 95 SE with 3.0L. I was just about to post a bunch of pics of the progress and mods. I had previously converted to an SVT engine, so my path is a bit different in that I already have a later model top feed rail and SVT induction, cam etc. I am very conversant in the 95 vacuum secondary and OBD1 issues, as well as solutions for the bad wiring found on most 95s.
I am going without secondaries in the intial build, but I do have an SVT LIM converted to vacuum. (I've done this twice).
Mone is a ported 3.0L with SVT cams. I'll be posting shortly....no pretty powder coating though....only have money for go fast stuff right now.
PS: Beautiful asthetics....keep it up on the 3L!
i would suggest removing the heads for the porting , since you already have to change the mount , the cost of a couple head gaskets and head bolts is worth the piece of mind of knowing there is no metal shavings in the engine, much easier to port the heads on a bench anyway
p.s. dont forget the exhaust ports
or you can spend a few hours grinding down the mount to fit between the heads for free ...
a few hours Brian? More like 1/2 an hour!![]()
And as for grinding the heads, I would never just stuff the holes and grind away, even with a vacuum on. If the heads are going to stay on the engine, at the very least tape over every hole but the one you are working on and crank the motor over to close the valves on that cylinder. Then make sure it is 100% clean before going on to the next hole and opening the valves. I personally wouldn't remove the heads on your engine Joe. I wouldn't replace the rod bearings either if your motor is actually that low in mileage. I don't know who would be installing the rod bearings, but as simple as it is, an inproper install could lead to premature failure down the road especially if the crank is knicked in the process by accident, etc... I personally would leave them alone as low mileage stock bearings will be more than sufficent.
See, that's what I was thinking about. No need to open an engine that has been properly built by FORD. The carfax says the car was bought by the salvage place in '06 with the 18k. The car was hit on the passenger side rear door area and the frame was bent. The motor was pulled within that year ('06) and has been stored since inside a climate controled warehouse. The motor is dusty, but as shown in the pics, it wasn't plugged. I don't know what could have been plugged because they left so much on the motor yet. Maybe the exhaust ports?:shrug:
I just don't ever want to pull this out again, and I think opening the engine will bring me more problems down the road because I am not a motor builder and don't have a f'ing clue about that kind of thing. Ford did it right the first time, so why fix what is not bad.... :shrug:
I don't even know how to "turn the motor over to close the valves" :duh:
I know that buckshot suggests the bearing replacement on any engine bought from a JY, and that you would be dumb not to go in there. I see his point, if you have experience doing that type of thing.....
I know someone on CEG has had a few problems with installs because of just dropping the motors in after picking them up from the yard. Not sure, but that is the word on the street.
Should I just use the 3L plastic upper and not even worry about porting the heads?
I really never wanted to have to make these decisions, 2.5L FTW!
Do I have to port my SE lower intake?
My final thoughts for the build:
MOTOR
-keep the SVT UIM regardless of HP #s (so I must port heads)
-keep original secondaries
-using 2.5 pan and pickup tube
-only replace what is needed
-pre-lube everything
-paint whatever I can
-install headers
-install DMD with longer bolt
-install 2.5 valve and timing covers
-install new AC compressor and drier
-new serp. belt
-finally connect my oil pressure sending unit :crazy:
-cut crank shaft down?(not sure what to do here yet, need to do more reading I think)
pre98 Rod-shift TRANS
-slick shift forks
-quaife diff
-zetec final drive
-new seals
BRAKES
-new ebrake cables
-warmonger rears with painted calipers
-Baer 13" fronts
-stainless lines all around
So why don't I have any volunteers to come to my house and finish this???
