zorrex
Enjoys the Abuse
So why don't I have any volunteers to come to my house and finish this???
Just come on over to Aircougar Performance
If you're interested in a custom machined LIM I have at least 1.
I was wondering what you're going to do about a tune with OBD1.
The shift rod mechanism is much superior to the cable mechanism!
I can always mess with the LIM later if I am unhappy with the runability. To loose a couple HPs over it doesn't matter to me. Thank you though.
-I don't know anything about tuning process' so I didn't know I would have a problem tuning OBD1. Is there something I need to do, or somewhere I need to go for that? I thought my only option was to get a pre-programmed chip by mail order.... :shrug:
So rod shift is good? Most SVT guys say they don't like the way it feels compared to cable....
Hey REEBS, maybe there is a SVT for sale around by me and you could come pick it up and do my swap for me while you are in town...... pickup Bagged and Todras on your way through too......
for tuning you are going to need a chip since you have OBDI. NPG I believe can burn chips. if you leave your stock injectors the car will run. but it would be better to use some 19# injectors.
Are SVT injectors the 19# ones? And do the 19# injectors plug and play in a OBD1?
Will I need dyno #s and charts to send to NPG to get the correct tune burned chip?
you might want to talk with rkneshaw (sp?) as I think he converted injectors.
Isn't rkneeshaw's car a '96 which would be OBD2 and the injectors would plug in, right?
If I were you, I would definitely forgo the porting for now. Get the plates to seal up the fuel valley in the heads, and just bolt up your 2.5L sh-t. This way you don't have to worry about tuning or injector swapping or anything like that until you have the thing running. It's not your best power option but with your lack of mechanical experience, I think you'd be smart to bolt it together & get it running as easily as possible. Once it's going, you can do things like port the heads, upgrade injectors, or tune as you desire.Should I just use the 3L plastic upper and not even worry about porting the heads?
this has always been one of your options,you may have just overlooked it b/c of all the people doing ported 3l/2.5 combo's. personally i would've went w/a 04+3l(better cams)headers,fuel rail mod,and exper. w/uim combos later.
I'm sure you saw where I said that it would not be his best performance option. Given his self-proclaimed lack of mechanical experience and his desire to get it up and running. Yes, that's exactly what I'm suggesting.Are you suggesting to use the entire 3L longblock and bolt down the bugzuki plates to cover the 3L injector valley and use the se LIM ontop of unported 3L heads?!?!?
