I’m going to build a forged motor after this one pops, I’m going to be running e85, I want to see if I can skirt past danger just with the cooling factors of the e85. I already installed a complete fuel system to run regular pump gas so I can always go back.(braided lines, filters and pump) thought about meth injection but decided I wanted less clutterGlad us old timers found this post. Great to see someone actually do it. I remember about 10 years ago when someone got pretty close and had to bail. I would love AWD with the kind of horsepower my car makes. My question is why not build the engine with forged internals and not worry about it....ever? I popped 5 stock engines on 8 to 10 pounds of boost before building my engine in 2015. 9 years of 20 plus pounds of boost and abuse. The only issue I have is keeping clutches in for more than 5 years.
I’ve heard that too… I know for a fact if you don’t fabricate new mounts for the rear subframe, you can drill all 10,000 spot welds and pull the whole trunk/strut tower/trunk/frame rail assembly and swap it for the contour.This thread is bringing all the old OG's out of retirement lol
I remember back in the day....like at least 15 years ago there was a legend about a ford tech that had an SVT with all the x-type drivetrain swapped in. Never posted here, never saw any pics...nothing. Just a story.
And here's this dude just making magic happen before our eyes!
This is verbatim the setup I'm planning for my ongoing 3L build. Love it!I have got to change this cooling setup. So many failure points. Remove factory water pump and cam pulley… Same side inlet outlet radiator, I can scoot it over too. Electric water pump, pwm controlled through the ecu based on the temp sensor, so no thermostat. Eliminate all the metal coolant lines. Small oil cooler, remote mount oil filter and sandwich plate. 2 hoses from the engine to the radiator/ water pump.
It’s a couple bucks but man how that would clean things up and make it a pleasure to do repairs.This is verbatim the setup I'm planning for my ongoing 3L build. Love it!
yeah those look amazing holy ****.Had to put the forged focus rs 19’s on! Control arms are out right now because I’m building tubular replacements, the entire rear will be full tubular with a QA1 coilover setup, I’m ditching the divorced setup (shock and spring)
View attachment 13464View attachment 13465View attachment 13466
yeah this right here is perfect.
