got the line fixed today. ordered some colder plugs
i dont have any way of loading a tune. all my tuning has been on a dyno
what should the colder plugs be gapped at?
installed the oil temp gauge today, getting antsy to drive the car, just waiting to hear back from the dyno shop to get a time
i know that this would have been a million times easier to do with the motor out, but what wire do i need to tap into to set up a switch to let the fan run after the motor is shut down
Do the miles roll on the odometer? The car won't run long with the cluster not working properly. I can't remember if the speedo or the odometer is unhooked the car will just die when driving it after a handful of miles..... I looked around for some harness's/ecu/keys for you but I didn't find anything. Good luck with your search. - JOE
im looking at an xcal, and if the vehicle was returned to stock the tunes will be on the tuner, can i override those tunes or is it locked into that vehicle? or can new tunes be put on there
and with no interior i will hear it all the time. it really freaked me out the first time it primed
