UPDATE:
Hey everyone, we are roughly at the halfway point of the install. I ran into a question though. I recall reading that the stock 19# injectors might be a tad bit too small to work with forced induction. I believe they max out before 300hp. I have 42# green top injectors that I was planning on using, but Greg mentioned that they might be too big to use. For what it's worth, I am boosting a pretty much stock CSVT 2.5L engine.
I am only running around 8psi boost (38mm wastegate) so I'm not sure if I will even max out the stock 19# injectors. and I'd hate to use these green tops if they will cause me to run too rich or idling problems. Greg will be using a "Sniper" tuning software if that makes any difference.
So my options are, try tuning with stock 19# injectors and see if I run too lean, and if those don't work, put in the green tops and hope we can tune the computer to send a short enough pulse at idle, or the third option is to try and find some 24# injectors. However, most 3.0L engines from the past ten years actually have 19# injectors. So it would be a tad harder to find specifically 96 to 99 DOHC 3.0L Taurus/Sable injectors :blackeye:. I unfortunately read that just because they're light blue, doesn't mean that they flow 24#. So it gets tricky to find actual 24# injectors, since even color doesn't matter.
