Thank you very much for the reply, but I'm a bit thrown off by two different opinions going on in this thread :crazy:. What I gather is that no one thinks that I should keep my stock injectors in lol. However, what I replace them with is where issues arise.i understand. but ford put 24 puonders in a 3l N/A FOR A REASON. no offence, but ghetto moding is stupid. just because something works doesnt mean its correct or works properly. why not just use duck tape to fix a lower control arm while your at it?? cuz its not correct
The reason I am hesitant to use the 42# injectors is that I was told they will cause a rich idle, and may even be rich while driving. So I see your point and agree that I won't be maxing these injectors out (that's for sure lol), but from what I read, since they are so much bigger than stock, the computer will have trouble sending a short enough pulse at idle to compensate for the huge size difference. With only a slightly bigger injectors, say 24# injectors, I would be running at a higher duty cycle, but the tuning would need less adjusting.
According to beyondloadedSE, Demon did some datalogging awhile back and 24lb injectors were at 66% duty cycle at 215 whp (~262 bhp). This is about 95% duty cycle with 19 lb injectors. So in other words, he claims "No way you're getting to 300 bhp on 19 lb injectors."
Also, will I still be able to use the stock MAF with either the 42# or 24# injectors? Or will I need a bigger MAF with the 42# injectors?
