hotdimmes
question...if the rust converting primer spray isn't high heat, then won't that fail first, making the rest of the high temp primer and paint moot?
Brian, what does the fluid coming out of the trans smell like?
For what its worth, my clutch did all of the above and I hated every minute of it. When it comes back out ill be replacing it. Did you go with a 3+ or a regular 3
not sure but it is definately oil.
I went with the stage 3+. its getting better, I think that is fully broken in now also.
Looking at all that tubing has me all twisted up inside. :laugh:
Once everything is running correctly I will either work on the hot side piping, tubro oil feeds, the intercooler or installing and wiring up the turbo timer and LC-1 wideband controller.
If you get it all buttoned up by Monday afternoon, bring it up here for a few...
Casey is supposed to be here all day Monday working on the paint again...
