all my fuses are good, pulled each fuse and checked it...im thinking either a short, a bad/missing ground or maybe a crossed power/ground somewhere? i mean, we left the harness in the car, so everything just got disconneced not fully removed...so going off the harness,
- the PCM grounding bolt is tight and wasnt removed.
- i have a ground off the firewall, pass side, that goes to the passenger mount
- i have a ground near the pass headlight, coming out of a harness that runs behind the coolant reservoir and p/s reservoir that splits, half into a plug near the PCM grounding bolt and the other half goes down the tower towards say the alternator
- my positive battery hookup goes to one big bolt on the starter
- remote wire hooks up from power to the small terminal on the starter
- negative terminal grounds to the transmission bolt, and has a smaller ground wire bolting to the frame under where the intake filter sits
- i have a ground bolting to the frame under the fuse box, that runs to the tranny bolt? ..But im thinking this might have to go to the negative terminal? its very long and seems like it went onto the tranny bolt. Theres even a little clip on the tranny to hold it it seems...
so anything im missing here that would cause this? Im going to double check the plastic rail on the rear valvecover that attaches the starter cable to the alternator power, but im 99% sure they were both tight. and you cant really screw that up anyways....only one terminal on that rail per side.
Im trying to think of where a ground and a power may have been crossed during install, but I cant think of any off the top of my head. the only other thing i can think of, is on the alternator theres a little tiny grey plug that connects and i think it has a sketchy connection. would that cause this? or do i need to completely follow the wiring harness from the PCM box to the drivers side? Since it was left in the car i know i didnt wire anything backwards or whatever because i didnt touch it.
im also going to try a good battery too, but i want to find out this sizzling/bad smell/sparking issue when the battery gets hooked up. i dont know where the sizzling noise comes from but id assume near the battery.
edit: heres a few pics of stuff...
on this, from my gfs 95, looks like it has 3 smaller grounds. where do each of them connect to? so i can trace mine...
heres my starter....left big one goes to positive terminal, top big one goes to the plastic rail for the alt, and small one is remote..correct?
heres my fusebox...looks normal? no missing fuses or anything that i need?
where could a power / ground be crossed ?
