Ok heres a few pics of my remaining plugs!
this one was taped off, so obviously for a reason haha. it comes off the fuel rail and has 5 wires. maybe for 2.5L imrc or something?
this plug comes off the fuelrail as well, its the middle plug of the 3 with the IAC and the TB plug. It has a white with green striped wire and and brown with green stripe wire i believe. For EGR? Which i do not have on the ST22plug
I think this one goes to the back of your coolant arm.. I think it's the temp switch locates driver side facing the firewall on the coolant arm thing.. With I had a pic but it's the thing that comes out of the side of the block that all the coolant lines hook onto.
this one i believe is the TPS, comes off the back plastic rail. it splits off to a wire with the green plug which i have connected already.
and heres my spare harness, its layed out as if you looking into the bay from the front of the car. the 2 most bottom ones being the mystery ones. the big grey one TPS? and the green plug beside it is the one i have connected. and that last one...the long one, its also a 2pin, and it has a white with red stripe wire and a solid purple? wire...
The one that's white red and purple I don't have plugged in. It's taped and zip tied up, I might have been the knock sensor on the back of the block, if you have the sensor then plug it in, if not no worries, do as I did. But it doesn't throw a code, only codes I throw are O2 sensor codes and EGR CODES, also the one to the far right is it triangle shaped? If so it's your VSS plug, located on the transmission and it's important, must plug it in, it's the vehicle speed sensor.
and i have these left, they for the 02 sensors i have cappped off?
I don't know much about the O2 sensors, mine are reading bad, as far as eliminating them ? Idk.. No help from me there..
