OB1
Everyone keeps mentioning 24lb injectors, I thought Joey said that this would come w/ 36lb units. I could be wrong or something could have changed but I just want to make sure. Maybe the difference is b/n stage 1 & 2?
While we're on the the subject (and keeping with the theme of "relatively low cost") would a 3" --> 2.25" y-split setup flow well enough for a 3L turbo?
I am thinking of just replacing the "main" piping with 3" pipe and keeping the "y-split" section of my stock SVT exhaust- changing the res & mufflers, too.
Of course, I'll need a 3" cat, too- Tom or Joey, do you happen to know what size inlet a new cat would need?
We decided not to paint the front intercooler since most here would like to paint their own words. Like I will paint NPG for my business name
+10 characi can't wait for stage 3!!! :drool::drool::drool:
But wont the tune need to e dif for hte 3L and a dif spring for more psi? And also are you still painting the SVT on the front mopunt intervooler?>
Which in Mike's case, he could probably go with the 7psi spring and 24# injectors. By upgraded trans, do you mean clutch as well? With as easy as it is to swap out injectors, you might as well go that route with a good tune. The headers alone should bump your power levels from the already dyno'd stage 1 kit.And you've got the insurance with the built tranny.
Mark
Did anyone else notice in the pics below how the power steering cooler was mounted flat? That won't cool very well with it mounted that way. I would suggest mounting it upright like it's suppose to be either behind the FMIC or in front of it, but not flat underneath it like it is in these pics. Either that or replace the cooler all together with a small rail type transmission cooler.
YOu know what? The tune would def have to be dif cause going to a 3L from a 2.5 you have to have it tuned to run right. Yeah it runs but def not the way it should. YOure going from a engine that has a IMRC to a engine that doesnt. YOu have to comp for that in the tune
Not to be a jerk, but how do YOU know it won't cool very well? :shrug:
Putting it in front of the IC will work but then it blocks air to the intercooler, an already sensitive and critical piece of the turbo kit.
Putting it behind the IC means it is already getting warmer air so why bother.
Putting it underneath the intercooler means it will get it's OWN cross section of untouched air. We aren't BLOCKING the air to the PS cooler, we are just positioning it lower down so it gets its own uninterupted airflow and minimizes the chances of parts vibration and rubbing a hole into either the AC condenser or the intercooler. Ask several people with the ADC/streetflight kit what happens with the air-water heat exchanger in front of the condenser. It rubs a hole in the condenser and the AC pressure blows a hole through it. Voila, NO AC anymore. :shocked: Its very hard to isolate it correctly for long term usage.
On the other hand, this is just how WE chose to do it because we felt it was the best compromise with the setup.
Yes, GOOD EYES....You may choose to mount it in front of or behind your intercooler if you choose to buy one of these kits. We never said it was a requirement because it was basically a non-issue since positioning is up to the owner. If you ask us, this is how WE would recommend you place it (because we thought it out before hand).
For you guys who do autocrossing alot you should upgrade to a larger PS cooler anyway they would easily fit in the fender well and the cooler even come with their own fan too. It up to you if you want to spend money where it is not needed. Show me proof that the cooler is being affected by temps or better than that show me failed power steering pumps because of pump heat. Let me get real techinical here if you take a flat surface that has resistance the air will build a pressure area in front of the FMIC or Condensor the air will flow to the least resistance or lower pressure area which is on the sides and the lower side of the FMIC. This air that is not directed through the restricted FMIC will be the air that will pass by the fins on the PS cooler. Take a high speed fan mayeb two and tape a cardboard flap under the FMIC and tell me the flap doesn't move.
The opening in the air vent doesn't mean that the air will only travel straight. The whole bottom end of the bumper acts as a tunnel which will have higher velocity and pressure through the middle but the whole tunnel will have air movement even on the edges which will extract heat off the fins.
If someone will show me facts and or temps differences I will add a sperate cooler on the passenger side fender well with a high speed fan and add it to the price if you like. Sorry If this comes off wrong but we already discussed this me and tom and we understand your concerns. If I was one looking at the whole picture I would have mentioned why don't you have an large oil cooler because you are running a turbo now which acts as a heater and thins out your oil.
I guess to sum it up guys you can always improve anything if you want to spend the money but I built this kit on well rounded concept at a price most kits won't sell for.
Thanks joey
