elraido
I kant speel
Limited? 2.5 or 2.2 (assuming all GT's had the 2.5)?
It's the lower end of the GT model. So it's cloth, 2.5, and no turbos. I don't need turbos anyways. This is the most powerful four cylinder I've ever owned.
Yeah I don't need turbos. I just need a decent/fun car that's going to last me quite a while, gets decent mileage, and gets around well.
From the reading I did, they did put turbos in the higher end GTs. It was actually a twin turbo setup from what I read. I would assume one turbo for each side is why they did two.
My Cougar started acting up lately. About a month ago it wouldn't start. I whacked the top of the fuel pump with my hand and it started right up... It's been perfect until two days ago. Now it won't idle for the first few seconds on cold start unless I give it gas. No CELs. When I restart it the car it will idle but it's a bit rough for the first few seconds. I do have a header leak that is getting worse (crack in header.... ). I have to add a flex pipe and get that header welded but it's been a little too cold to work on it. Thoughts? I wonder if I should order another return pump or pop the IAC off (less than a year old) and clean it out. The engine is in really good shape since I swapped a low mile 3L in last year and it's been running great since.
I know that, I just swapped the whole assembly, so essentially I have two working pumps and two bad fuel sending units. :laugh:The pump won't affect the gauge just the float/resistor. You can swap those around if one works and one doesn't.
Sounds like an amateur move dude.I never grabbed my propane heater out of my extra garage
...This cold weather sucks!
