Blackcoog
I think I was finally able to get rid of those bees I had behind the brick near my front door. I bought some product called "Delta Dust" on Amazon and blew that stuff into the entrance at night/early morning when they were inside the nest. Since then I haven't seen a bee. I know there are still some alive in the nest so I'm going to pump that •••• in every night for at least a week. I found another nest under my deck that I took care of with a raid can. I have to knock that down once I know they are gone. Damn bees!
I pulled a motor out of a Cougar yesterday (swapping a clutch) and I almost finished pulling a motor out of a SVT yesterday (3L swap). Took about 3 hours (2 guys). I'm waiting on parts for both so I couldn't do much more.
I'm also working on some air scoops to put behind the grill of the Jag. It's a curved scoop to direct air up into the intake tubing behind the front grill. The intake tubing comes into the grill area from the top. Another XF owner asked me to look into it. I wasn't sure if it would make much of a difference, but my car did notice the increased air flow. I bent some sheet metal up for one side (I didn't have enough to build one for the other at the time). The car popped check engine light after a short trip because one side was seeing more air flow vs. the other. I still need to find time to build another one. I need to figure out how to make my sheet metal bends cleaner. Even if I had a sheet metal brake I don't think I could make all the needed bends with it.
