IIRC 17# Injectors limit to 125hp crank..You have a good motor. Lucky. If you are making 122 at the wheels then you have to be in the 140 range at the crank.
that comment makes no sense at all. why in the world would the injectors be limited to 125 hp at the crank when that is what the engine is rated for? that and striker just said he didn't change the fuel injectors to get his 140 hp crank.
and again for the numbers you guys are throwing around. my SE made 140 whp stock. no way with the mods are you getting to SVT levels ...
